[GRASS-user] problem with Rast_get_x_value functions
Jarek Jasiewicz jarekj at amu.edu.pl
Sun Jul 18 09:47:02 EDT 2010
Thanks Glynn
> You cannot dereference a "void*", nor perform arithmetic on one.
> If you want to access the map as an array of FCELL values, use
> Rast_allocate_f_buf() and Rast_get_f_row(). There is no point in using
> the map's native type if you're just going to convert the data anyhow.
The problem was how to write warper function to read and convert data
from any type to any type
it is alrady done, I didn't know I must use (c*size) to instead of c
passing pointer to function
thanks a lot
Jarek
