[GRASS-user] Re: v.rast.stats
Micha Silver micha at arava.co.il
Thu Jul 22 15:22:32 EDT 2010
On 07/22/2010 10:36 AM, Sandile Gumede wrote:
> Hello Micha,
> Can you please put all the steps you did here?
I think all the steps are already below.
> On Sat, Jun 19, 2010 at 9:57 PM, Micha Silver <micha at arava.co.il
> <mailto:micha at arava.co.il>> wrote:
>     Hello Sandile:
>     I tried to duplicate your steps and it seems to work for me.
>     Here's what I did:
>     wget ftp://trmmopen.gsfc.nasa.gov/pub/gis/3B42RT.2010032900.1day.tif
>     wget ftp://trmmopen.gsfc.nasa.gov/pub/gis/3B42RT.2010032900.1day.tfw
>     gdalinfo 3B42RT.2010032900.1day.tif
>     Driver: GTiff/GeoTIFF
>     Files: 3B42RT.2010032900.1day.tif
>     Size is 1440, 480
>     Coordinate System is `'
>     Origin = (-180.000000000000000,60.000000000000000)
>     Pixel Size = (0.250000000000000,-0.250000000000000)
>     ---- Note: no projection info above ----
>     ---- Now I use the -projwin option of gdal_translate to select a
>     small window
>     gdal_translate -a_srs EPSG:4326 -projwin 34.0 33.0 36.0 29.0
>     3B42RT.2010032900.1day.tif rainfall_il.tif
>     ---- GEOGCS entry now shows 4326 ----
>     g.mapset map=ASTER_DEM loc=WGS84
>     ----- A location setup as EPSG:4326----
>     r.in.gdal israel.tif out=rainfall_il
>     r.univar rainfall_il
>      100%
>     total null and non-null cells: 77760000
>     total null cells: 0
>     Of the non-null cells:
>     n: 77760000
>     minimum: 0
>     maximum: 34
>     range: 34
>     mean: 0.364583
>     mean of absolute values: 0.364583
>     standard deviation: 3.45241
>     variance: 11.9192
>     variation coefficient: 946.948 %
>     sum: 28350000
>     ----- Now using an existing catchment vector map ----
>     v.rast.stats vect=arava_wsheds rast=rainfall_il colpre=precip
>     v.info <http://v.info> -c arava_wsheds
>     Displaying column types/names for database connection of layer 1:
>     INTEGER|cat
>     CHARACTER|label
>     DOUBLE PRECISION|area_km
>     INTEGER|precip_n
>     DOUBLE PRECISION|precip_min
>     DOUBLE PRECISION|precip_max
>     DOUBLE PRECISION|precip_range
>     DOUBLE PRECISION|precip_mean
>     DOUBLE PRECISION|precip_stddev
>     DOUBLE PRECISION|precip_variance
>     DOUBLE PRECISION|precip_cf_var
>     DOUBLE PRECISION|precip_sum
>     ---- and some values ----
>     v.db.select arava_wsheds
>     cat|label|area_km|precip_n|precip_min|precip_max|precip_range|precip_mean|precip_stddev|precip_variance|precip_cf_var|precip_sum
>     21|Jordan|1055.231692|2|0|0|0|0|0|0||0
>     19|Hidan|987.811979|2|0|0|0|0|0|0||0
>     28|Og|124.122969|||||||||
>     36|Zarqa|273.606213|||||||||
>     24|Kidron|122.460114|||||||||
>     9|Darga|289.012122|||||||||
>     6|Arugot|236.365116|1|0|0|0|0|0|0||0
>     26|Mujib|1277.546513|2|0|0|0|0|0|0||0
>     ---- (Many catchments have 0 or no value because of the small
>     region I chose. The global data is 1/4 degree resolution and my
>     region is only 2 deg E-W.)----
>     HTH...
>     Micha
>     On 06/17/2010 12:50 PM, Sandile Gumede wrote:
>>     Hi
>>     It is still giving me -NULL value error.
>>     Do you think maybe its the way I downloaded my rainfall data?
>>     This is the site where I downloaded my data sets_
>>     ftp://trmmopen.gsfc.nasa.gov/pub/gis/ _and this data covers the
>>     whole world, the only thing I did was to clip a specific region
>>     (using coordinates) that is in South Africa to do my analysis. I
>>     used a bash script to download and project the data, see below:
>>     #!/bin/bash
>>     gdal_translate -of GTiff -co "PROFILE=GeoTIFF" -co
>>     "INTERLEAVE=PIXEL" -co "COMPRESS=LZW" -co "TILED=YES" -a_srs
>>     EPSG:4326 -a_ullr 18.2987501 -33.6795831 19.1712501 -34.3487498
>>     3B42RT.2010032900.1day.tif TRMMLast1day.tif
>>     On Thu, Jun 17, 2010 at 8:41 AM, Sandile Gumede
>>     <akasandile at gmail.com <mailto:akasandile at gmail.com>> wrote:
>>         Hi
>>         the whole world, the only thing I did was to clip a specific
>>         region (using coordinates) that is in South Africa to do my
>>         analysis. I used a bash script to download and project the
>>         data, see below:
>>         #!/bin/bash
>>         wget
>>         wget
>>         -34.3487498 3B42RT.2010032900.1day.tif TRMMLast1day.tif
>>         2010/6/15 Micha Silver <micha at arava.co.il
>>             On 15/06/2010 14:35, Sandile Gumede wrote:
>>>             Hi
>>>             If I run g.region rast=rainfall -p, I get:
>>             OK, what you've done here is change the current region to
>>             match the raster "rainfall".
>>             Can you now try:
>>             v.rast.stats -c vect=catchments rast=rainfall pref=precip
>>>             projection: 3 (Latitude-Longitude)
>>>             zone:       0
>>>             datum:      wgs84
>>>             ellipsoid:  wgs84
>>>             north:      33:40:46.49916S
>>>             south:      34:20:55.49928S
>>>             west:       18:17:55.50036E
>>>             east:       19:10:16.50036E
>>>             nsres:      0:00:05.01875
>>>             ewres:      0:00:02.18125
>>>             rows:       480
>>>             cols:       1440
>>>             cells:      691200
>>>             and If I run r.univar rainfall, I get the following output:
>>>              100%
>>>             total null and non-null cells: 691200
>>>             total null cells: 0
>>>             n: 691200
>>>             minimum: 0
>>>             maximum: 3094
>>>             range: 3094
>>>             mean: 22.0228
>>>             mean of absolute values: 22.0228
>>>             standard deviation: 76.1639
>>>             variance: 5800.94
>>>             variation coefficient: 345.841 %
>>>             sum: 15222164
>>>             On Tue, Jun 15, 2010 at 12:22 PM, Hamish
>>>             <hamish_b at yahoo.com <mailto:hamish_b at yahoo.com>> wrote:
>>>                 Micha wrote:
>>>                 > The only unusual thing I notice above is that the
>>>                 resolution settings
>>>                 > for the raster are different N-S and E-W. This
>>>                 came from the original
>>>                 > tiff (see below) which also has rectangular pixels,
>>>                 that is perfectly normal for a lat/lon map away from
>>>                 the equator.
>>>                 longitude scales a cos(lat).
>>>                 > (the v.rast.stats module creates a temp raster at
>>>                 the *current region's
>>>                 > resolution* settings, which might be different
>>>                 from this rainfall
>>>                 > raster's rectangular resolution...)
>>>                 the results of:
>>>                 g.region -p rast=mapname
>>>                 r.univar mapname
>>>                 could help.
>>>                 Hamish
>>>             Kind Regards
>>>             TS Gumede
>>>             CSIR, Meraka Institute
>>>             072 258 1650
>>>             This mail was received via Mail-SeCure System.
>>             Micha Silver
>>             http://www.surfaces.co.il/
>>             Arava Development Co.  +972-52-3665918
>>         Kind Regards
>>         TS Gumede
>>         072 258 1650
>>     Kind Regards
>>     TS Gumede
>>     072 258 1650
>     Micha Silver
>     http://surfaces.co.il
> Kind Regards
> TS Gumede
> 072 258 1650
Micha Silver
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100722/539326c0/attachment-0001.html
