[GRASS-user] Convert shapefile format to vector GRASS format
Etienne DELAY (deust 2010) etienne.delay at etu.unilim.fr
Tue Jul 27 12:37:28 EDT 2010
Le 27/07/10 17:45, Susana Arciniegas a écrit :
> I installed Grass 6.4.ORC6 (2010)in windows 7. I can not load point data (shapefile format).
 I created Gis Data directory / Project location and mapset. But I can
not import vector data, only
I can import raster data, and vector data from tutorial data (ex:
spearfish60 / Permanent/ vector / Archsites.
> How can I convert shapefile to vector Grass format?
> Thank you for answer
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hi Susana,
can you explain the procedure to import vector?
because if you happened to import examples ... I think the function module.
Is that way you appear in your layer list vector
v.in.ogr dsn=/home/elcep/Bureau/VineyardHeroique/VineyardHeroique.shp
output=teste min_area=0.0001 snap=-1
Cordialement
Etienne DELAY
Deust "Webmaster et gest. d'intranet" (IDSkype : etienne.delay.tic)
Master IUP "valorisation du patrimoine et aménagement du territoire"
