[GRASS-user] Re: Installing r.area
Hamish hamish_b at yahoo.com
Thu Jul 29 12:23:55 EDT 2010
fyi I get what it does now, and just fixed a small bug in it which was
stopping it from reading CELL maps.
I have the full svn version of grass built from source, and from the
addons svn dir I built it with:
  make MODULE_TOPDIR=/usr/local/src/grass/svn/grass65/
(I just run grass out of the source dir, so never 'make install' it)
at minimum I think you have to cd to the main source dir and do ./configure
if you installed grass from a package, check if there is an associated
-dev package, and then point MODULE_TOPDIR towards where it install its
files.
Hamish
LeeDaniel wrote:
> Thanks for the replies! I've tried it out and here are my
> responses to the
> suggestions:
> @ Markus - Downloaded the script and put it in my scripts
> folder, made it
> executable and made it assigned rights to myself. Just as a
> test I tried
> opening it as a GUI and, lo and behold, it worked. However,
> it couldn't find
> my add-on path, of course, when I tried to add r.area. So I
> went to the
> terminal and entered:
> export GRASS_ADDON_PATH?$GISBASE
> g.extension r.area
> Now things looked good. It did the following:
> Fetching <r.area> from GRASS-Addons SVN (be
> patient)...
> A    r.area/main.c
> A    r.area/description.html
> A    r.area/Makefile
> Checked out revision 42910.
> - Great, got the files needed. Then it started compiling:
> Compiling <r.area>...
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/bin.i686-pc-linux-gnu
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include/grass
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/lib
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/bin
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/etc
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/driver
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/driver/db
> mkdir -p
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/fonts
> test -d OBJ.i686-pc-linux-gnu || mkdir -p
> gcc
> -I/usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include
> -O2
>    -DPACKAGE=\""grassmods"\"
> -o
> OBJ.i686-pc-linux-gnu/main.o -c main.c
> main.c:19:23: fatal error: grass/gis.h: No such file or
> directory
> compilation terminated.
> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> ERROR: Compilation failed, sorry. Please check above error
> messages.
> - So it looks like it was able to make a bunch of
> directories. I checked,
> they're there, new as of today. The entire directory of
> /usr/src/packages/
> is new. However, GRASS wasn't able to compile. I checked
> for
> /usr/src/packages/BUILD/grass-6.4.0RC6/dist.i686-pc-linux-gnu/include/grass/gis.h
> since it seemed that it was looking for it and couldn't
> find it, and
> discovered that the directory
> is completely empty. Could that be the problem? I also
> tried using
> sudo g.extension r.area
> And got the usual error that I have to be in GRASS GIS to
> run the program. I
> didn't try starting GRASS as a super user because I don't
> want to do
> anything wrong and I also don't want it to install r.area
> only for super
> users.
> But that would be a nice way of loading add-ons, because it
> looks like I
> wouldn't have to have the source code all on my hard drive.
> Any idea why
> it's not working?
> @ Micha - Tried running it with g.extension (see above); it
> didn't work, so
> I tried to do the thing manually again. Entered
> svn checkout https://svn.osgeo.org/grass/grass-addons/
> grass-addons
> to get the source codes. It worked and all the source codes
> were downloaded
> to my home directory in the folder grass-addons. Then I
> navigated into the
> directory
> ~/grass-addons/raster/r.area/
> and entered the command
> ./configure
> This is similar to last time; last time, I also had been
> inside the
> directory when I tried the commands. But I thought hey,
> maybe I'd copied the
> source codes wrong. Sadly, that doesn't seem to be the
> problem; just like
> last time, I got the message
> bash: ./configure: No such file or directory
> I then tried it as super user. Same problem.
> Any other ideas? Thanks a lot again for the help,
> everyone!
> Daniel
