[GRASS-user] Multi-scale Segmentation
Jesús Moreno Brotóns jesusmorenobrotons at gmail.com
Tue Jun 1 06:20:37 EDT 2010
The directory was correctly located, the problem was that the object code
(directory OBJ-i686-pc-linux) had been created in r.seg/src/ not in r.seg,
so I had to run make install on r.seg/src/ . Now it seems properly
installed.
Thanks
Jesús
El 1 de junio de 2010 11:27, Markus Neteler <neteler en osgeo.org> escribió:
> You likely need to indicate where the source code is if you didn't
> move r.seg into the raster directory of the GRASS source code.
> For example:
> make MODULE_TOPDIR=$HOME/grass64-src/
> make MODULE_TOPDIR=$HOME/grass64-src/ install
> Markus
> 2010/6/1 Jesús Moreno Brotóns <jesusmorenobrotons en gmail.com>:
> > Oops! I forgot to add the error :). After running make install, it
> returns:
> > make: *** No rule to make target `install '. Stop
> > Jesús
> > El 1 de junio de 2010 10:15, Markus Neteler <neteler en osgeo.org>
> escribió:
> >> Hi Jesús,
> >> since we cannot guess the error please post it to the list :)
> >> Markus
> >> > Hi there,
> >> > These days I followed the thread of this email. I didn't know r.seg,
> and
> >> > I
> >> > very interested in testing. I downloaded the module from the web site
> >> > (http://www.ing.unitn.it/~grass/ <http://www.ing.unitn.it/%7Egrass/>),
> and compiled correctly but I get an
> >> > error
> >> > when I tried to install it (make install). Has anyone had this
> problem?
> >> > Regards
> >> > 2010/5/27 Nikos Alexandris <nikos.alexandris en felis.uni-freiburg.de>
> >> >> > > Aleksander Yanovskiy:
> >> >> > >> There is also r.seg GRASS module for doing variational
> >> >> > >> segmentation
> >> >> > >> (http://www.ing.unitn.it/~grass/<http://www.ing.unitn.it/%7Egrass/>).
> Some information about it can
> >> >> > >> be
> >> >> > >> found in
> http://download.osgeo.org/osgeo/foss4g/2009/SPREP/2Thu/Parkside%20GO4/15
> >> >> > >> 00 /Thu%20G04%201545%20Zatelli.pdf
> >> >> > > Great piece (hidden so long... :-p). I wonder why there is no
> >> >> > > reference
> >> >> > > about it in GRASS AddOns [1] or else in the wiki.
> >> >> > Since it is a Wiki, please do it :)
> >> >> > Markus
> >> >> I don't risk by that my head... being hunted from people that I don't
> >> >> know
> >> >> because I took the liberty to "do it" huh? :D :D
> >> >> (Of course I will but honestly, I've never heard of r.seg before!)
> >> >> Nik
> >> >> > > [1] http://grass.osgeo.org/wiki/GRASS_AddOns
> >> >> > > _______________________________________________
> >> >> > > grass-user mailing list
> >> >> > > grass-user en lists.osgeo.org
> >> >> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> >> > Laboratorio de SIG y Teledetección (LASiTE)
> >> > Instituto Universitario del Agua y del Medio Ambiente (INUAMA)
> >> > Universidad de Murcia
> >> > Edificio D
> >> > Campus de Espinardo
> >> > Telef: +34 868-887605
> >> > jesusmb en um.es
> > Edificio D
> > Campus de Espinardo
> > jesusmb en um.es
Edificio D
Campus de Espinardo
jesusmb en um.es
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100601/03df7ff4/attachment.html
