[GRASS-user] Re: Importing Dems with r.in.xyz
Hamish hamish_b at yahoo.com
Mon Jun 7 05:08:36 EDT 2010
Hanlie Pretorius wrote:
> > I don't think it's this bug because this bug discards only one line of
> > data. I don't get any data in because the number of coordinate pairs
> > in the file is less than the number of cells in the defined region.
Markus Metz:
> Weird. In 6.4, r.in.xyz does import a file where the number of
> coordinate pairs is far less than the number of cells in the defined
> region. (I just did a simple test with two input lines and a region
> with 26.5 million cells, got clean import and correct result)
sorry, I'm not really grasping what the problem is. If you suspect
there is something weird going on can you make the .xyz.bz2 file
available for me to download, and supply the output of r.univar
`wc -l` and `r.in.xyz --verbose`?
Hamish
