[GRASS-user] Re: Problems with v.what.rast
Martin Landa landa.martin at gmail.com
Wed Jun 9 05:40:44 EDT 2010
2010/6/9 Rebecca Bennett <rabennett at ymail.com>:
> I have deleted the column I added and tried all command line permutations of
> v.db.addcol map=Contour_points_cats at PERMANENT layer=1 `col="rast_value
> DOUBLE PRECISION"`
> v.db.addcol map=Contour_points_cats at PERMANENT layer=1 `columns="rast_value
> DOUBLE PRECISION"`
ones more - the correct form is (without ``)
v.db.addcol map=Contour_points_cats at PERMANENT layer=1 col="rast_value
DOUBLE PRECISION"
Note that you can edit only vector maps from the current mapset.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
