[GRASS-user] Re: bash script
Markus Metz markus.metz.giswork at googlemail.com
Thu Jun 24 04:38:30 EDT 2010
Sandile Gumede  wrote:
> I'm using ubuntu, I installed grass from the synaptic. So the script to
> start grass is in /usr/bin then the file name is grass64 (/usr/bin/grass64)
> and the scripts are in /usr/lib/grass64 then inside grass64 folder you get
> other folder like scripts and so on. That is why in my script I wrote:
> # start GRASS
> GISBASE=/usr/bin/grass64
/usr/bin/grass64 is the script starting GRASS, not a directory
in your case I think
GISBASE=/usr/lib/grass64
followed by
export PATH="$GISBASE/bin:$GISBASE/scripts:$PATH"
should do it because r.in.gdal should be in $GISBASE/bin = /usr/lib/grass64/bin
now tell GRASS where its libraries are:
export LD_LIBRARY_PATH=$GISBASE/lib:$LD_LIBRARY_PATH
also do
export GRASS_LD_LIBRARY_PATH=$LD_LIBRARY_PATH
$GISDBASE/lib is nonsense because GISDBASE is the location of a GRASS database
HTH,
Markus M
> # path to the scripts
> GISBASELIB=/usr/lib/grass64
> But I tried to export the PATH you gave me, still giving me an error of
> r.in.gdal not found
> On Thu, Jun 24, 2010 at 9:16 AM, Markus Metz
>> > [snip]
>> > # first our GRASS, then the rest
>> > export PATH=$GISBASE:$GISBASELIB/scripts:$PATH
>> Try
>> See also etc/init.sh for inspiration
>> Markus M
> Kind Regards
> TS Gumede
> CSIR, Meraka Institute
> 072 258 1650
