[GRASS-user] Trouble running Grass 7
Ned Horning horning at amnh.org
Tue Jun 29 08:09:36 EDT 2010
Hi - I am trying to install Grass 7 in a local directory and the
installation seems to have gone ok but when I run it I get the following
error:
WARNING: Nviz extension (3D view mode) disabled. Reason:
/home/nedhorning/bin/grass70/lib/libgrass_datetime.7.0.svn.so: wrong ELF
class: ELFCLASS32
g.list: error while loading shared libraries: libgdal.so.1: cannot open
shared object file: No such file or directory
I'm not too concerned about the Nvis error but the problem with
libgdal.so.1 is preventing GRASS from starting. I have a file
/usr/lib/libproj.so.1 which is a link to the shared library
/usr/lib/libproj.so.0.6.6. Is this a version problem?
I have GRASS 6.4 ORC6 running just fine.
Thanks in advance for any advice.
Ned
