[GRASS-user] r.fillnulls error
    maven apache
    apachemaven0 at gmail.com
    Mon Mar  1 09:04:31 EST 2010
2010/3/1 maven apache <apachemaven0 at gmail.com>
> 2010/3/1 Hamish <hamish_b at yahoo.com>
> maven apache wrote:
>> > When I use the r.fillnulls command to resample a map:
>> > r.fillnulls input=aa output=ab tension=40 smooth=0.1
>> > It show me that: taking too long to find points for
>> > interpolation--please change the region to area where your
>> > points are. Continuing calculations...
>> > What does it mean?
>> It means you should read the fabulous "NOTES" section of the r.fillnulls
>> man page.  ;-)
>> (the warning is harmless in this context, ignore it)
>> Hamish
>> ps::devs- use r.to.vect -zb in the r.fillnulls script? v.surf.rst doesn't
>> need them and it could save a lot of memory etc if lidar data with many
>> holes is thrown at it.
>> Oh, thanks, I see it.
> However what perplexing me these days is to call grass in command line
> model in windows platform,forward a message:
> HI:
> I want to run grass in a command line model, however when I write a bat,it
> works just for 6.3 version , and some command can not work for example I can
> run g.version ,rather than r.fillnulls.
> The grass variable bat is :
> @echo off
> rem *******Environment variables***********
> rem Set GRASS Installation Directory Variable
> set GRASSDIR=F:\anzhuang\GRASS
> rem set GISBASE=D:\GrassDataBase
> set GISRC=C:\Documents and Settings\Administrator\.
> grassrc6
> rem Set Path to utilities (libraries and bynaries) used by GRASS
> set PATH=%GRASSDIR%\msys\bin;%PATH%
> set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%GRASSDIR%\extrabin;%PATH%
> set
> PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%
> set
> PATH=%PATH%;%GRASSDIR%\bin;%GRASSDIR%\lib;%GRASSDIR%\scripts;%GRASSDIR%\etc;%GRASSDIR%\sqlite\lib;%GRASSDIR%\sqlite\bin;
> rem Path to the proj files (notably the epsg projection list)
> set GRASS_PROJSHARE=%GRASSDIR%\proj
> And I write a work bat :
> r.in.gdal
> input=D:\data\hdf5\new\OMI-Aura_L3-OMTO3e_2009m0729_v003-2009m0731t020127.tif
> output=aa location=al
> g.gisenv set=LOCATION_NAME=al
> g.region rast=aa
> r.null map=aa setnull=-1.267e+30--1.268e+30
> r.out.gdal input=ab format=GTiff
> output=D:/OMI-Aura_L3-OMTO3e_2009m0729_v003-2009m0731t020127.tif
> It does not work,.
> I wonder why?
> In fact what I am trying to do is to call grass in my web application(like
> the web processing service),now I want to handle the hdf5 data,the following
> is my idea:
> 1) use gdalinfo to get the information of the he5,(the gdal model in grass
> 6.3 does not support this command, the 6.4 support)
> 2) change the subdataset to geotiff, use gdal_translate
> 3) import the tiff to grass and create a new location according the tif
> 4) log in to the new location use g.gisenv
> 5) set some sepical cell data to null by using r.null....
> 6) Interpolation the null data using r.fillnulls.
> 7) export the map to geotiff.
> So anyone can give some advise?
I am in hurry, anyone can help me?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100301/dc7b673b/attachment.html
