[GRASS-user] make command (install add on)
Markus Neteler neteler at osgeo.org
Sat Mar 20 07:05:39 EDT 2010
On Fri, Mar 19, 2010 at 5:29 PM, schorschli <matthiasoswald at hotmail.com> wrote:
> Hi,
> I want to test the interesting net.analyze addons (mostly because of
> v.net.distance). I've downloaded it but now not able to install it... :-(
> Following the instruction first I changed the directory to the path where
> the downloaded addons are saved:
> cd Documents/temp/net.analyze
> Then I tried the make command:
> make MODULE_TOPDIR=/Applications/GRASS-6.4.app/Contents/MacOS/
Are you sure about this directory?
MODULE_TOPDIR should point to the GRASS installation directory which
contains bin/, lib/ and other GRASS stuff.
On Linux it compiles ok but I have no experience (nor access) to MacOSX.
Markus
> As a result I get the an error:
> make: *** Makefile: Is a directory.  Stop.
> Does someone know what this could mean and what I'm doing wrong?
> Tusend tack,
> schorschli
