[GRASS-user] grass 7 and ubuntu start up
Vincent Bain bain at toraval.fr
Thu Mar 25 09:31:34 EDT 2010
Hi Matthew,
just an idea : did you check if grass70 exists in your path and if so,
is it executable (you can type sth like ls -l /usr/bin/grass* in a term)
Yours,
Vincent.
Le jeudi 25 mars 2010 à 12:24 +0000, Matthew Mulbrandon a écrit :
> Hello,
> Just installed grass 7.0 using the latest snapshot binary march 20
> (grass7.0.svn-i686-pc-linux-gnu-20_03_2010) and ubuntu 9.10. I type in
> grass70 in the shell and nothing happens. No error but also no gui. I
> try some gui commands and it says command not found. Nothing really
> works but the program seems to activate.
> I use grass 6.4 often but am at a loss as to what the problem is.
> Thanks,
> Matthew
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> ______________________________________________________________________
> The New Busy is not the old busy. Search, chat and e-mail from your
> inbox. Get started.
> grass-user mailing list
