[GRASS-user] problems starting Grass6.3 on Windows
Vishal Mehta vishalm1975 at gmail.com
Wed May 12 16:44:05 EDT 2010
one more thing Martin: i noticed that the last copy action on installing
Grass6.5svn failed. here's the log extract (first few and last few lines):
Create folder: C:\Documents and Settings\Vishal Mehta\My Documents\GIS
DataBase
Output folder: C:\Program Files\GRASS-65-SVN\icons
Extract: GRASS.ico... 100%
Extract: GRASS_Web.ico... 100%
Create folder: C:\Program Files\GRASS-65-SVN\msys\grass
Copy to C:\Program Files\GRASS-65-SVN\msys\home\C:\Documents and
Copy failed
Completed
-Vishal
On Wed, May 12, 2010 at 1:29 PM, Vishal Mehta <vishalm1975 at gmail.com> wrote:
> As i mentioned earlier, Grass6.3 was working earlierwith my own mapsets -
> but now is not. The only difference since then that i can remember is that I
> installed Qgis, and started experimenting with postgresql an dpostgis as
> well...i dont quite see if that could impact Grass runs..but am just
> guessing here..
> Martin, I tried your May 12 Grass 6.5 daily build.
> I get the same error regarding g.region. When i try to run it from the
> command line, it enters grass. but then i cant use d.mon, so i try gis.m and
> at this point i get the same original error.
> is this something to do with the gis manager? I tried to start with
> wx-python gui but got a different error there.
> Vishal
> On Tue, May 11, 2010 at 10:30 PM, Martin Landa <landa.martin at gmail.com>wrote:
>> Hi,
>> 2010/5/12 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>:
>> > Is there a why of you use grass 6.3?
>> > How about you try grass 6.4R6?
>> or daily builds
>> http://josef.fsv.cvut.cz/wingrass/
>> Martin
>> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa<http://gama.fsv.cvut.cz/%7Elanda>
> Vishal K. Mehta, PhD
> Scientist
> Stockholm Environment Institute - US
> 133 D St Suite F
> Davis CA 95616
> www.sei-us.org
Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100512/fb16057e/attachment.html
