[GRASS-user] Warnings while importing Kompsat-2 images
Luis Lisboa luislisboa1975 at gmail.com
Mon May 24 11:44:06 EDT 2010
Hi there
I imported Kompsat-2 images using r.in.gdal and I gfot this warnings:
rning 1: TIFFFetchNormalTag:ASCII value for tag
"DocumentName" does not end in null byte
Warning 1: TIFFFetchNormalTag:ASCII value for tag
"ImageDescription" does not end in null byte
Warning 1: TIFFFetchNormalTag:ASCII value for tag "Artist"
"HostComputer" does not end in null byte
Projection of input dataset and current location appear to match
What is the origin of this? Or what can I do to avoid this? Kompsat-2 images
are followed by an header txt. can that be useful?
Because it has recognized projection, the resolution is the same and even nº
of cols/rows.
Thanks
Luis
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100524/5055cd68/attachment.html
