[GRASS-user] Get current location projection in a Python Script
Kim Besson kimbesson1981 at gmail.com
Tue May 25 03:50:10 EDT 2010
Greetings
I'm building a GRASS Python Script to automatically import a set of data to
my location. At GRASS book (chapter 3.3.3) it uses g.proj -wf to to check
current location projection. Can I use the same command in Python to
retrieve the same?
And how about calling gdalwarp in a Python-GRASS Script? can it be called
and used by a Python_GRASS Script? if so, is there any Python example with
that?
Regarding "g.proj -wf" command. I get a lot of information. I suppose
GDALWARP can read this right ? If not, How can I obtain current Location
EPSG code?
Thanks
Best regards,
Kim
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100525/9298cc08/attachment.html
