[GRASS-user] Re: Trying python scripts.
Carlos Grohmann carlos.grohmann at gmail.com
Fri May 28 08:41:49 EDT 2010
Hello Marcello.
It's good to _finally_ see you here :)
I tried your script and it worked for me, but I had to change the last line from
sys.exit(main())
to:
main()
could you try that?
best
Carlos
On Fri, May 28, 2010 at 08:23, Marcello Gorini <gorini at gmail.com> wrote:
> Nikos Alexandris wrote:
>> Marcello Gorini wrote:
>>> Thanks for the try. I tested it again with other rasters, but I got the
>>> same error. Could it possibly be something related to the 64bits
>>> architecture?
>> I don't think so. I work with Kubuntu Lucid 64 bit :-)
>>> Or could GRASS be sending the outcome somewhere else?
>> Negative. You are running the script from within a grass-session (as you
>> wrote
>> in the first post). Let's try to take this step by step. What is the
>> result of
>> each of the following commands:
>> ls -l myscript.py
>> g.gisenv
>> g.region -p
>> r.info map1
>> r.info map2
>>> Well, I guess that eventually I will go around this problem or even bump
>>> into the solution, but the most important thing to say is that I
>>> appreciated the effort and that it was a very good reception to this
>>> list.
>> Bah... it was only me trying to not forget the basics with python scripts.
>> You will get better and more precise replies from other advanced users and
>> developers.
>>> Thank you very much Nikos. And thank you also for the explanations with
>>> respect to the right way to answer posts. I will do my best to make my
>>> posts as clean and explanatory as possible.
>> You are warned, you might get yourself into trouble ;-p
>> Cheers, Nikos
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> OK, thank you, so let's go step by step:
> ls -l myscript.py
> result:
> -rwxr-xr-x 1 marcello marcello 1227 2010-05-28 08:13 myscript.py
> g.gisenv
> result:
> GISDBASE=/home/marcello/grassdata
> LOCATION_NAME=Ocean_floor
> MAPSET=level4
> MONITOR=x0
> GRASS_GUI=tcltk
> g.region -p
> result:
> projection: 99 (Mercator)
> zone:       0
> datum:      wgs84
> ellipsoid:  wgs84
> north:      3947900
> south:      3633400
> west:       -7366700
> east:       -7022600
> nsres:      3700
> ewres:      3700
> rows:       85
> cols:       93
> cells:      7905
> r.info map1
> result:
>  | Layer:    map1                           Date: Thu May 27 18:48:30 2010
>  | Mapset:   level4                         Login of Creator: marcello
>  | Location: Ocean_floor
>  | DataBase: /home/marcello/grassdata
>  | Title:     ( topmod )
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 255
>  |   Data Type:    FCELL
>  |   Rows:         1177
>  |   Columns:      1388
>  |   Total Cells:  1633676
>  |        Projection: Mercator
>  |            N:    6358450    S:    2003550   Res:  3700
>  |            E:   -3920150    W:   -9055750   Res:  3700
>  |   Range of data:    min = 0.000000  max = 10000.000000
>  |   Data Description:
>  |    generated by r.mapcalc
>  |   Comments:
>  |    if(topmod > 0, 0, -topmod)
> r.info map2
> result:
>  | Layer:    map2                           Date: Thu May 27 18:49:29 2010
>  | Title:     ( topmod2 )
>  | Timestamp: none
>  |   Data Type:    FCELL
>  |   Rows:         1177
>  |   Columns:      1388
>  |   Range of data:    min = 1000.000000  max = 1000.000000
>  |   Data Description:
>  |   Comments:
>  |    if(topmod > -2, 1000, topmod)
> Now just to emphasize :)
> Result of "r.info outmap":
> ERROR: Raster map <outmap> not found
> Can you make anything out of it?
> Best regards,
> Marcello.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Trying-python-scripts-tp5109105p5112658.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
Prof. Carlos Henrique Grohmann - Geologist D.Sc.
Institute of Geosciences - Univ. of São Paulo, Brazil
http://www.igc.usp.br/pessoais/guano
http://lattes.cnpq.br/5846052449613692
Linux User #89721
________________
Can’t stop the signal.
