[GRASS-user] Language of installed manual
Luigi Ponti lponti at inbox.com
Mon May 31 10:49:59 EDT 2010
Hello,
I could not find any further reply to this, and I just would like to
mention that the problem (mixed languages in manual pages when
installing wingrass from http://josef.fsv.cvut.cz/wingrass/grass64/) is
gone as of WinGRASS-6.4.SVN-r42329-1-Setup.exe.
Thanks and regards,
Luigi
On 19/02/2010 16:33, Martin Landa wrote:
> Hi,
> 2010/2/18 Glynn Clements [hidden email] <http://osgeo-org.1803224.n2.nabble.com/user/SendEmail.jtp?type=node&node=4599112&i=0>:
>> The default locale is "C", which behaves the same as if no locale is
>> set (i.e. no call to setlocale()).
>> LC_ALL takes precedence over the individual LC_* variables and LANG,
>> so you may need to use:
>>        export LC_ALL=C
> I have already tried to put `LC_ALL=C` to package.sh and recompile
> *GRASS*, but it didn't seem to help (module --interface-description
> still returns localized text).
> Martin
Thanks Martin. Just to detail further my report, in case it is useful
(sorry if redundant):
Installed last available WinGRASS-6.4.SVN-r41105-1-Setup.exe of 19 February.
If I do for example:
r.colors --interface-description
what is get is:
<?xml version="1.0" encoding="CP1252"?>
<!DOCTYPE task SYSTEM "*grass*-interface.dtd">
<task name="r.colors">
    <description>
        Creates/modifies the color table associated with a raster map layer.
    </description>
    <keywords>
        raster, color table
    </keywords>
    <parameter name="map" type="string" required="no" multiple="no">
        <description>
            Nome della mappa raster in input
        </description>
        <keydesc>
            <item order="1">name</item>
        </keydesc>
        <gisprompt age="old" element="cell" prompt="raster" />
        <guisection>
            Required
        </guisection>
    </parameter>
</task>
You can see there is English description plus some Italian text
depending on how far the translator got. It is the same text I get in
the g.parser GUI when invoking r.colors without arguments. I think this
is fine since I have an Italian locale. However, the HTML manual page of
r.colors is a partial *Czech* translation.
Kind regards,
Luigi
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100531/638b8c2b/attachment.html
