[GRASS-user] Re: g.extension (e.g. to install i.landsat.toar)
Gabriele N. gis.gn at libero.it
Tue Nov 2 17:05:19 EDT 2010
Markus, still does not work.
I saw some differences compared to the old script. To understand ... which
is the part that has been changed to fix this?
GRASS 6.4.0 (utm_wgs84):~ > g.extension i.landsat.toar
Fetching <i.landsat.toar> from GRASS-Addons SVN (be patient)...
A    i.landsat.toar/landsat_set.c
A    i.landsat.toar/local_proto.h
A    i.landsat.toar/main.c
A    i.landsat.toar/description.html
A    i.landsat.toar/landsat.c
A    i.landsat.toar/earth_sun.c
A    i.landsat.toar/landsat.h
A    i.landsat.toar/landsat_met.c
A    i.landsat.toar/Makefile
A    i.landsat.toar/earth_sun.h
 U   i.landsat.toar
Estratta revisione 44172.
Compiling <i.landsat.toar>...
mkdir -p /build/buildd/grass-6.4.0/bin.i686-pc-linux-gnu
mkdir: impossibile creare la directory `/build': Permesso negato
make: *** [/build/buildd/grass-6.4.0/bin.i686-pc-linux-gnu] Errore 1
ERRORE: Compilation failed, sorry. Please check above error messages.
GRASS 6.4.0 (utm_wgs84):~ > g.extension i.landsat.acca
Fetching <i.landsat.acca> from GRASS-Addons SVN (be patient)...
A    i.landsat.acca/tools.c
A    i.landsat.acca/local_proto.h
A    i.landsat.acca/main.c
A    i.landsat.acca/description.html
A    i.landsat.acca/algorithm.c
A    i.landsat.acca/Makefile
 U   i.landsat.acca
Compiling <i.landsat.acca>...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/g-extension-e-g-to-install-i-landsat-toar-tp5662708p5699112.html
Sent from the Grass - Users mailing list archive at Nabble.com.
