[GRASS-user] Area weighting for vectors
Micha Silver micha at arava.co.il
Wed Nov 3 16:36:17 EDT 2010
On 11/03/2010 04:55 PM, Hanlie Pretorius wrote:
> Hi,
> I need to add some attributes from a soil polygon layer to a catchment
> polygon layer using area weighting. In other words, the contribution
> of the soil layer needs to be weighted by the amount with which its
> polygons overlap the catchment polygons.
> For example, suppose I want to weight soil infiltration rates. 30% of
> a catchment polygon overlaps with soil type 1 and 70% overlaps with
> soil type 2. Now I want a new attribute in the catchment polygon that
> takes 30% of the infiltration rate of soil type 1 and adds it to 70%
> of the infiltration rate of soil type 2.
> How can I do this in GRASS?
The most straight forward way is using v.rast.stats. This module adds to
a vector attribute table the univariate statistics from a raster. So
you'll first convert the soil map to raster, then run v.rast.stats using
the catchment polygons as the vector and the soil infiltration as the
raster.
> Thanks
> Hanlie
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
