[GRASS-user] Re: Constrain the output of v.random
Maris Nartiss maris.gis at gmail.com
Thu Nov 4 07:15:13 EDT 2010
Please open a wish ticket at http://trac.osgeo.org/grass and describe
what should v.random do to statisfy Your analysis. Probably someday
someone will modify v.random to contain such feature.
Thanks,
Maris.
2010/11/4, leonidas <leonidas_liakos at yahoo.gr>:
> I need the defined "Number of points to be created" to be inside the
> polygons. If I follow your method some of them will remain out of the
> polygons. I need to get 10 points that will fall inside the polygons NOT to
> define 10 points and then select only the points that they are in polygons.
> Thanks for your reply!
> http://osgeo-org.1803224.n2.nabble.com/Constrain-the-output-of-v-random-tp5704498p5704721.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
