[GRASS-user] creating network only input points
Maris Nartiss maris.gis at gmail.com
Sat Nov 6 05:09:16 EDT 2010
Hello,
can You, please, clarify Your idea and problem?
By definition - every line has two nodes and may have extra vertices.
Point is line with only one node. If You need just own nodes, put them
in different layer.
Maris.
2010/11/6, Ricardo Rodríguez <ricardorodot02 at gmail.com>:
> hello.
> how to create a network so that nodes are only the input points , as this
> grass gis adding nodes that make noise in my calculations, as are the
> beginning and end of each line and  points outside the same network, this to
> be, and how I can make a network with my real points only.
>  I am using grass gis 65 svn in ubuntu linux of 64 bit
> Thanks for your answers
> Ricardo Rodríguez
> Univalle
