[GRASS-user] Re: Need some help in converting a contour map to DEM map...
Achim Kisseler ak7 at jupiter.uni-freiburg.de
Tue Nov 9 07:41:58 EST 2010
Hey,
just downloaded it.
It is in lat-long, isnt it? Or a different projection?
I figured out, that the hight column is not numeric, but character.
Maybe thats he problem?
using:
v.surf.rst input=kontour at mapset elev=kontour_dem
after converting hight to integer and
setting resolution to
0:00:01
I get: see attached
Achim
Am 09.11.2010 13:12, schrieb nikmor:
> hey Achim
> Thanks for replying.I tried many things like v.surf.rst, r.surf.contour etc
> but still I could'nt get the desired output, sometimes it runs for a
> long-long time which never ends and sometimes after the resolution being
> changed it gives weird output and which cannot be viewed in NVIZ it says
> loading failed. I had posted the problems that I faced but did not get
> reply/help, so this time around I have uploaded the datafile so that one can
> just try out the thing on their machine and see if its possible and works
> fine on their system and kindly help me in my work. I have spent more than 2
> weeks on this and have not succeeded yet. I think the problem is with
> resolution. I need serious help from someone.
> thanks
> Nikhil
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname   : snapshot.png
Dateityp    : image/png
Dateigr??e  : 44940 bytes
Beschreibung: nicht verf?gbar
URL         : http://lists.osgeo.org/pipermail/grass-user/attachments/20101109/d27324eb/snapshot-0001.png
