[GRASS-user] v.rast.stats over a large vector file
razmjooeis at faunalia.co.uk razmjooeis at faunalia.co.uk
Fri Nov 26 08:43:08 EST 2010
Many thanks for your suggestions.
I will give it try and let you know which one works.
Cheers
Sab
> I used StarSpan to do something similar (but with less vector feature:
> 6000). It worked pretty well. Maybee worth a try?
> http://starspan.projects.atlas.ca.gov/doku/doku.php
> Daniel
> On Fri, Nov 26, 2010 at 10:41 AM, Markus Metz
> <markus.metz.giswork at googlemail.com> wrote:
>> On Fri, Nov 26, 2010 at 12:32 PM,  <razmjooeis at faunalia.co.uk> wrote:
>>> Dear list
>>> I am trying to run v.rast.stats for a large vector file. It contains
>>> around 700000 buildings representing buildings.
>>> here is my g.region info
>>> g.region -p
>>> projection: 99 (Transverse Mercator)
>>> zone:       0
>>> datum:      osgb36
>>> ellipsoid:  airy
>>> north:      183010.45829976
>>> south:      153516.19024768
>>> west:       513122.49174945
>>> east:       555953.95182415
>>> nsres:      4.99987592
>>> ewres:      5.00017045
>>> rows:       5899
>>> cols:       8566
>>> cells:      50530834
>>> THe problem I am having is the process is extremely slow. It has done
>>> 150
>>> features out of 700000 areas after 2 hours.
>>> I need just the average raster value within each building (feature).
>>> My questions are:
>>> - Is there something I can do to speed up the process?
>>> - Is there a way just to get the average value rather than the whole
>>> set
>>> of statistical parameters (I am not even using -e option)
>> You could try v.rast.stats2 from grass-addons, it should complete in
>> less than 1 hour. When using v.rast.stats2 and grass 6.4, you also
>> need r,univar.zonal from grass-addons (not needed for grass 6.5).
>> Markus M
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
