[GRASS-user] r.univar.zonal not installing
Vishal Mehta vishalm1975 at gmail.com
Mon Oct 11 15:41:54 EDT 2010
Hi Laura,
Did you have to recompile an updated Grass65 from svn?
I am still unable to install this either from g.extension or compiling it
from source..
Vishal
On Fri, Oct 8, 2010 at 1:43 AM, Laura Poggio <laura.poggio at gmail.com> wrote:
> Dear all,
> it worked using g.extension on an updated version of GRASS65.
> Sorry for my late answer but in the past days I was unable to try.
> Thank you
> Laura
> On 5 October 2010 20:17, Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Aug 9, 2010 at 5:41 PM, Laura Poggio <laura.poggio at gmail.com>
>> wrote:
>> > Dear all,
>> > since a while, I am trying to compile the r.univar.zonal addon on a
>> Fedora11
>> > 64 bit machine and using GRASS 6.5
>> > I used:
>> > svn co https://svn.osgeo.org/grass/grass-addons/raster/r.univar2.zonal
>> > cd r.univar2.zonal/
>> > make MODULE_TOPDIR=~/bin/grass65/grass6_devel/
>> > No errors were detected, but when I try:
>> > make MODULE_TOPDIR=/home/myuser/bin/grass65/grass6_devel install
>> > I am getting:
>> > if [ "" != "" ] ; then \
>> >                 for dir in  ; do \
>> >                         make -C $dir install ; \
>> >                 done ; \
>> >         fi
>> > Various other addons were installed using these steps, then I think I am
>> > missing something here ... Thank you in advance for any hints!
>> Perhaps that comes from the directory name which I find slightly
>> confusing:
>> GRASS 6.4.1svn (nc_spm_08):~ > ls -la grass-addons/raster/r.univar2.zonal/
>> total 76
>> drwxr-xr-x  3 neteler neteler  4096 2010-02-18 21:40 ./
>> drwxr-xr-x 53 neteler neteler  4096 2010-09-23 12:04 ../
>> -rw-r--r--  1 neteler neteler  1806 2010-02-18 21:36 globals.h
>> -rw-r--r--  1 neteler neteler   624 2009-04-09 10:44 Makefile
>> -rw-r--r--  1 neteler neteler  8426 2010-02-18 21:36 r3.univar_main.c
>> -rw-r--r--  1 neteler neteler  2286 2010-02-18 21:36 r3.univar.zonal.html
>> -rw-r--r--  1 neteler neteler  9829 2010-02-18 21:36 r.univar_main.c
>> -rw-r--r--  1 neteler neteler  4411 2009-04-09 10:44 r.univar.zonal.html
>> -rw-r--r--  1 neteler neteler  3358 2009-02-24 08:27 sort.c
>> -rw-r--r--  1 neteler neteler 15223 2010-02-18 21:36 stats.c
>> drwxr-xr-x  6 neteler neteler  4096 2010-09-22 09:25 .svn/
>> GRASS 6.4.1svn (nc_spm_08):~ > grep univ
>> grass-addons/raster/r.univar2.zonal/Makefile
>> PROGRAMS = r.univar.zonal r3.univar.zonal
>> R3UNIVAR = $(BIN)/r3.univar.zonal$(EXE)
>> RUNIVAR = $(BIN)/r.univar.zonal$(EXE)
>> $(RUNIVAR): $(OBJDIR)/r.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
>> $(R3UNIVAR): $(OBJDIR)/r3.univar_main.o $(OBJDIR)/sort.o $(OBJDIR)/stats.o
>> -> PROGRAMS that does not reflect the directory name.
>> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar.zonal
>> WARNING: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
>> Fetching <r.univar.zonal> from GRASS-Addons SVN (be patient)...
>> svn: URL 'https://svn.osgeo.org/grass/grass-addons/raster/r.univar.zonal'
>> doesn't exist
>> ERROR: GRASS Add-on r.univar.zonal not found in repository or no network
>>       connection or another problem
>> But like this it works:
>> GRASS 6.4.1svn (nc_spm_08):~ > g.extension r.univar2.zonal
>> Fetching <r.univar2.zonal> from GRASS-Addons SVN (be patient)...
>> A    r.univar2.zonal/stats.c
>> A    r.univar2.zonal/sort.c
>> A    r.univar2.zonal/globals.h
>> A    r.univar2.zonal/r.univar.zonal.html
>> A    r.univar2.zonal/r.univar_main.c
>> A    r.univar2.zonal/r3.univar.zonal.html
>> A    r.univar2.zonal/r3.univar_main.c
>> A    r.univar2.zonal/Makefile
>>  U   r.univar2.zonal
>> Checked out revision 43799.
>> Compiling <r.univar2.zonal>...
>> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
>> gcc -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include  -g
>> -Wall  -fno-common -fexceptions -mtune=nocona -m64
>> -minline-all-stringops       -DPACKAGE=\""grassmods"\"
>> -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include -o
>> OBJ.x86_64-unknown-linux-gnu/r.univar_main.o -c r.univar_main.c
>> Proposals
>> @authors: rename directory to first program name
>> @Laura: please try g.extension
>> best,
>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101011/dcce2441/attachment.html
