[GRASS-user] v.db.join script
Jon Eiriksson jeir at hi.is
Tue Oct 12 06:01:58 EDT 2010
I apologise for possible double-posting - but it seems that I did not
send the email copied below to the correct address. If anyone has
experienced the v.d.b.join column definition/truncation problem
desacribed belowl and has some advice, I would be very grateful to
hear about it.
Best regards, Jon
I have a truncation problem with v.db.join. This has been raised
before -
([GRASS-user] Re: grass v.db.join
Gary Nobles
Fri, 12 Mar 2010 11:11:26 -0800)
- but I have not seen a solution. I have tried my own data, the
spearfish60 example data, and the example in Neteler and Mitasova's
book.
The new data columns are apparently defined as 1 character long, and the
data become truncated accordingly, much against my intention. I use
mysql.
Can anyone point out a solution? I copy a session with the spearfish60
data below.
Jon
GRASS 6.4.0 (spearfish60):~ > g.copy vect=soils,mysoils
Copy vector <soils at PERMANENT> to current mapset as <mysoils>
GRASS 6.4.0 (spearfish60):~ > db.select mysoils
cat|label
1|Aab
2|Ba
3|Bb
4|BcB
5|BcC
6|BeE
GRASS 6.4.0 (spearfish60):~ > db.in.ogr soils_legend.csv
out=soils_legend
Imported table <soils_legend> with 55 rows
GRASS 6.4.0 (spearfish60):~ > db.select soils_legend
id|shortname|longname
0|no data|no data
1|AaB|Alice fine sandy loam, 0 to 6
2|Ba|Barnum silt loam
3|Bb|Barnum silt loam, channeled
4|BcB|Boneek silt loam, 2 to 6
5|BcC|Boneek silt loam, 6 to 9
6|BeE|Butche stony loam, 6 to 50
GRASS 6.4.0 (spearfish60):~ > v.db.join mysoils col=label
otable=soils_legend ocol=shortname
GRASS 6.4.0 (spearfish60):~ > v.db.select mysoils
cat|label|id|shortname|longname
1|Aab|1|A|A
2|Ba|2|B|B
3|Bb|3|B|B
4|BcB|4|B|B
5|BcC|5|B|B
6|BeE|6|B|B
GRASS 6.4.0 (spearfish60):~ > db.describe -c mysoils
ncols: 5
nrows: 54
Column 1: cat:INTEGER:11
Column 2: label:CHARACTER:13
Column 3: id:CHARACTER:1
Column 4: shortname:CHARACTER:1
Column 5: longname:CHARACTER:1
GRASS 6.4.0 (spearfish60):~ > db.describe -c soils_legend
ncols: 3
nrows: 55
Column 1: id:CHARACTER:255
Column 2: shortname:CHARACTER:255
Column 3: longname:CHARACTER:255
Jon Eiriksson, Research Professor,
Earth Science Institute, University of Iceland,
Askja, Sturlugata 7,
IS-101 Reykjavik, Iceland.
Tel     +354 525 44 75
Fax     +354 525 44 99
Email   jeir at hi.is
Web    http://www.raunvis.hi.is/~jeir/
