[GRASS-user] Building 6.5: SQLite3 Error [SOLVED]
Maris Nartiss maris.gis at gmail.com
Fri Oct 29 08:52:04 EDT 2010
Just to clarify - You have to read FILE named config.log at source
directory  and look for last compilation command (i.e. gcc blabla). It
will give information WHY test failed and not simply WHICH one failed.
Just my 0.02
Maris.
2010/10/28, Rich Shepard <rshepard at appl-ecosys.com>:
> On Thu, 28 Oct 2010, Glynn Clements wrote:
>> That's coincidence; GRASS doesn't use cairomm.
>    Strange. Must be the weather.
>> For future reference: if you get configure errors, look at the bottom of
>> config.log. It will list the exact test being performed and any error
>> messages which were generated.
>    Almost always I see the same messages at the end of the log as I do when
> configure bails out. But, this is good advice and I thank you.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
