[GRASS-user] g.extension not working
Daniel Victoria daniel.victoria at gmail.com
Wed Sep 1 08:55:19 EDT 2010
I just issued "make install" and installed grass65 at
/usr/local/grass-6.5.svn. Now, g.extension tries to install
r.stream.order but complains about permissions. Taking ownership of
the install dir fixes the problem. So, what would be the "correct" way
to use g.extension, run grass as root or take ownership of the install
dir?
Cheers
Daniel
On Wed, Sep 1, 2010 at 2:39 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Yes, that's the reason then (same here).
>  We need to add a condition to skip the install ste in this case.
> Markus
> On 9/1/10, Daniel Victoria <daniel.victoria at gmail.com> wrote:
>> I do have /usr/bin/install installed. I run Ubuntu and coreutils is
>> the latest version.
>> One small quirk though. I compiled Grass 6.5svn running make but I did
>> not install it (make install). I'm running it straigh from the build
>> directory (start script at ./bin.i686-pc-linux-gnu and binaries at
>> ./dist.i686-pc-linux-gnu). Could that be related?
>> Thanks
>> Daniel
>> On Tue, Aug 31, 2010 at 10:01 PM, Hamish <hamish_b at yahoo.com> wrote:
>>> Daniel wrote:
>>>> Ok, g.extension works and downloads svn addons
>>> great! thanks for the confirmation.
>>>> but r.stream.extract compilation fails.
>>>> Bellow is the r.stream.order compilation log error.
>>>> make[1]: Leaving directory
>>> ok, so actually it built ok, but fails during installation:
>>>> Installing r.stream.order...
>>>> /usr/bin/install: cannot stat
>>> aka the "install" program is not installed.
>>> No idea what provides that on your linux distro, on Debian and Ubuntu
>>> it comes in the "coreutils" package.
>>> Hamish
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
