[GRASS-user] Importing a Scanned Map
David Kindem dkindem at gmail.com
Sun Sep 5 11:20:10 EDT 2010
The file is a .tif file with two associated files, a .wld and a
tif.aux.xml.
Dave
David Kindem
On Sep 5, 2010, at 11:01 AM, kapo coulibaly wrote:
> What format is the map in?
> On Sun, Sep 5, 2010 at 10:50 AM, David Kindem <dkindem at gmail.com>
> wrote:
> Hello,
> I am trying to import a raster map using r.in.gdal.  The map was
> previously georeferenced in Q-GIS.  When I run r.in.gdal, I receive
> the message that the projection of dataset does not appear to match
> current location.
> I used the location parameter to create a new location for the
> scanned map.  When I attempted to re-project the map from my new
> location into my intended GRASS location, I received the following
> error:
> Unable to get projection info of input map.
> Looking at the projection information, the projection for the
> scanned map and for my GRASS location match, with the exception of
> the cellhd.proj parameter.  The scanned map's cellhd.proj = 0
> (unreferenced/unknown).
> I'm not familiar with the function of the cellhd.proj.  Could
> someone shed some light on how I might be able to resolve the issue?
> Thanks,
> Dave
> David Kindem
> Grand Haven, MI
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100905/4b21a08e/attachment-0001.html
