[GRASS-user] WDPA vector files
Hamish hamish_b at yahoo.com
Thu Sep 16 20:01:38 EDT 2010
Tim wrote:
> I need to make some graphics showing WDPA protected areas.
> I am trying to import each IUCN type as a separate layer, from shapefile
> format.
>  have only done 3 of the 8, and each is taking between 24 and 48 hours.
> I am running out of time.  Does anyone already have these in GRASS format
> and would be willing to share?  Thanks!
you are probably running into the old "Florida Coastline" problem.
M.Metz: did you do something to improve this in trunk?
in a pinch you might try the v.in.ogr -c flag,
  -c   Do not clean polygons (not recommended)
but as it says, it's really not recommended to work with uncleaned data.
Hamish
