[GRASS-user] v.net.path extension
Mohammed Rashad mohammedrashadkm at gmail.com
Sat Sep 18 00:19:28 EDT 2010
try
wx.path python version.
but it will not fulfil your needs but more interactive than v.net.path
now it only support spearfish dataset
will extend to use any data if anyone needs
http://svn.osgeo.org/grass/grass-addons/gui/wxpython/wx.path/wx.path.py
On Fri, Sep 17, 2010 at 7:01 PM, Robbie Heremans
<robbie.heremans at gmail.com>wrote:
> Starting from a file with start and end positions  (x_start, y_start,
> x_stop, y_stop) and a vector map of roads, I have to find places on the
> roads where most people pass, assuming they will use the shortest path or
> path with the least cost.
> Is there a command in Grass that can do this (ic v.net.path for each record
> and summary  map of these shortest paths)?
> Any suggestions/examples?
> Robbie
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rashad
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100918/897027f1/attachment.html
