[GRASS-user] Two questions re 6.4 and OSX 10.4
Richard Chirgwin rchirgwin at ozemail.com.au
Sat Sep 18 17:47:25 EDT 2010
  Some days I don't pay attention - I slipped into a time-warp, actually
I'm on 10.5.8.
So I think confusion on the libraries is right. Mind you, I don't
actually use Nviz and can do without, but g.mkfontcap is failing as well.
Here's the config line I've been using, from the Wiki with some edits
(eg locating MySQL).
> ./configure --enable-sysv --with-x --with-opengl=x11 --with-cxx
> --with-freetype \
> --with-mysql=yes \
> --with-mysql-includes=/usr/local/mysql-5.1.40-osx10.5-x86/include \
> --with-mysql-libs=/usr/local/mysql-5.1.40-osx10.5-x86/lib \
> --with-freetype-includes=/Library/Frameworks/FreeType.framework/unix
> include \
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
> --with-gdal=/Library/Frameworks/GDAL.framework/Versions/1.6/Programs/gdal-config
> --with-proj-includes=/Library/Frameworks/PROJ.framework/Versions/4/unix/include
> --with-proj-libs=/Library/Frameworks/PROJ.framework/Versions/4/unix/lib \
> --with-proj-share=/Library/Frameworks/PROJ.framework/Versions/4/unix/share/
> --with-jpeg \
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-tiff \
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-sqlite \
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
> --with-fftw \
> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include \
> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib \
> --with-postgres-includes=/usr/local/pgsql/include
> --with-postgres-libs=/usr/local/pgsql/lib \
> --with-freetype \
> --with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include
> --with-nviz=no \
> --with-python \
> --with-tcltk-includes=/usr/local/include \
> --with-tcltk-libs=/usr/local/lib  \
> --with-blas \
> --with-lapack \
> --with-blas-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers
> --with-lapack-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers
> --without-motif \
> --with-opengl-libs=/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries
On 19/09/10 12:48 AM, William Kyngesburye wrote:
> Ah!  That old error.  When you said OS X 10.4.1, did you really mean that, or is it 10.4.11?
> This problem should be fixed in the system in 10.4.11, but 10.4.1 I think still had it.
> If you really are at 10.4.1, then you definitely should apply all updates to 10.4.11.  Also make sure you are using the last Xcode version possible for Tiger, 2.5 I think.
> Another possible problem here is that make is getting confused between the system OpenGL and X11 OpenGL libraries.  How are you configuring opengl and tcltk?
> On Sep 18, 2010, at 1:37 AM, Richard Chirgwin wrote:
>> William,
>> Make exits with an error in Nviz; /lib/nviz won't make. Here's the /lib/nviz error:
>>>     (cd /usr/local/grass-6.4.0/dist./lib; ln -f -s libgrass_nviz.6.4.0.dylib /usr/local/grass-6.4.0/dist./lib/libgrass_nviz.dylib)
>>> ld: cycle in dylib re-exports with /usr/X11/lib/libGL.dylib
>>> collect2: ld returned 1 exit status
>>> make: *** [/usr/local/grass-6.4.0/dist./lib/libgrass_nviz.6.4.0.dylib] Error 1
>> Richard
>> On 17/09/10 11:47 PM, William Kyngesburye wrote:
>>> --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
>>> On Sep 17, 2010, at 3:48 AM, Richard Chirgwin wrote:
>>>> William - I'm not getting as far as "make" yet. At configure, it fails:
>>>> Unable to locate External PROJ.4 includes.
>>>> This, even if I use:
>>>> --with-proj=/Library/Frameworks/PROJ.framework/Versions/4/Headers/proj_api.h
>>>> (I know that PROJ.4 is installed, I'm using 6.4.0-RC4 with no worries!)
>>>> Richard
> William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
