[GRASS-user] converting lines to polygons
Micha Silver micha at arava.co.il
Thu Sep 23 12:42:38 EDT 2010
On 09/23/2010 05:42 PM, Bryan Keith wrote:
>> On 09/22/2010 02:40 PM, Bryan Keith wrote:
>>>> On 09/22/2010 12:45 AM, Bryan Keith wrote:
>>>>> Hello,
>>>>> I'm using these commands:
>>>>> v.clean input=test_ln output=testclean_ln tool=snap,bpol thresh=0.2,0
>>>>> v.type input=testclean_ln output=testclean_bnd type=line,boundary
>>>>> v.centroids input=testclean_bnd output=testclean_py
>>>>> trying to convert a bunch of lines to 5 polygons.  I've tried lots of
>>>>> variations of v.clean including many snap thresholds, but I can only
>>>>> get
>>>>> 3
>>>>> polygons.  Is there something I'm doing wrong?
>>>> If it's only two missing, then just manually add centroids to those two
>>>> areas that are not yet polygons. (using v.digit)
>>> Well, it's two in this simple little example clipped from a larger file,
>>> and I have lots of files to process so I'm looking for an automated
>>> process.
>> Can you figure out why other areas were not closed? Maybe you need a
>> larger threshold value?
>> By opening the vector with v.digit you'll see by the color coding of the
>> nodes which are part of closed boundaries (dark green) and which are on
>> a "broken" boundary (red).
>> You'll also see quickly where you have centroids inside correct
>> boundaries, and where you're missing them.
> No, I can't figure out why the other areas were not closed.  A larger
> threshold value does not help.  I have never used v.digit, and I actually
> can't get anything to display with v.digit  Hmmm, I'm not sure what I'm
> doing wrong with v.digit
What OS are you on? what version of GRASS, and what GUI?
> I would be nice to be able to see where nodes aren't connected (I'm
> guessing that's the problem) and be able to measure how far apart they are
> from each other.  I'm surprised how increasing the threshold makes some
> boundaries that were correct incorrect.
Yes, Surprising. Can we see, as Markus M suggested, the output of v.info
-t or v.clean? Also what units is your data in? i.e the output of v.info
-g and g.region -p ?
Regards,
Micha
>>> Bryan
>>>>> Check out the line and polygons here:
>>>>> http://www.ideotrope.org/~bryan/lines.png
>>>>> http://www.ideotrope.org/~bryan/polygons.png
>>>>> Bryan
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>> This mail was received via Mail-SeCure System.
>>>> Micha Silver
>>>> Arava Development Co. +972-52-3665918
>>>> http://surfaces.co.il
>> Micha Silver
Micha Silver
