[GRASS-user] Grass-GIS 6.4 font bug in OSX
Richard Chirgwin rchirgwin at ozemail.com.au
Sun Sep 26 17:12:16 EDT 2010
I've just install 6.4 under OSX 10.5.8, and have run into a problem.
Reproduced in Spearfish:
d.vect bugsites - OK
d.vect bugsites display=attr attrcol=str1 - OK
d.vect bugsites display=attr attrcol=str1 font='Arial Italic'
produces this error, repeated many times:
The process has forked and you cannot use this CoreFoundation
functionality safely. You MUST exec().
Break on
__THE_PROCESS_HAS_FORKED_AND_YOU_CANNOT_USE_THIS_COREFOUNDATION_FUNCTIONALITY___YOU_MUST_EXEC__()
to debug.
Then the X monitor window closes.
Any ideas?
Richard
