[GRASS-user] Re: v.rast.stats locks up on wingrass (problem adding columns)
DGann tylerdrudolph at gmail.com
Fri Aug 19 11:28:59 EDT 2011
> My best advice is to try it for yourself and see if it works or not.
I did using 6.4.1 and got the error message reported by others:
C:/GRASS-64-SVN/scripts/v.rast.stats: line 268: v.db.addcol: command not
found
ERROR: Cannot continue (problem adding columns).
> since v.rast.stats is just a shell script combining a number of other
> GRASS modules, you could always just run the individual commands by hand
I am currently evaluating this as an alternative, though I am also batch
scripting through R and new to GRASS, so...  In the meantime...
> Please update to 6.4.2, using the latest of the nightly builds [0]
I updated to the latest nightly build (WinGRASS-6.4.SVN-r47756-1) and
resubmitted my job through R 2.13.1 (using spgrass6), and this time I get
the following error message:
execGRASS("v.rast.stats", flags="verbose",
parameters=list(raster="eosd_resample", vector="mcp80s", colprefix="p80"))
Error in system(cmd0, intern = TRUE) : 'v.rast.stats.exe' not found
Error in parseGRASS(cmd) : v.rast.stats not found
The script is indeed there, but I am not familiar enough with the inner
workings of GRASS to speculate on where the executable comes in....  Has
v.rast.stats been temporarily disabled in WinGRASS or is this something new?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-rast-stats-locks-up-on-wingrass-problem-adding-columns-tp6701826p6703669.html
Sent from the Grass - Users mailing list archive at Nabble.com.
