[GRASS-user] Re: [GRASS-windows] WinGRASS Python 2.7
Wed Aug 31 15:49:30 EDT 2011
Johannes Radinger wrote:
> So I checked the python.exe*32 (the only python that is running) in
> the taskmanager (after booting and starting the wxGUI). And although
> GRASS_PYTHON is set in the environmental variables to
> C:\Python27\python.exe, the python which is used is still the
> GRASS-Python in the path C:\Programm Files(x64)\GRASS
> 6.4.1\extrabin\python.exe
> So what causes this? How can I proceed? What should I check?
How did you set GRASS_PYTHON?
AFAIK, it's set in %GISBASE%\etc\env.bat; this will override any
global setting.
