[GRASS-user] IDW (or similar) and cost surface
Facundo Muñoz famuvie at alumni.uv.es
Wed Dec 7 02:25:45 EST 2011
I have implemented a while ago a cost-based kriging that I used exactly
in that way.
You can see the paper and sample code here:
http://www.geeitema.org/guenmap/index.jsp?opcion=resultados&idioma=en
There is a GRASS script that helps to compute the cost-based distances,
and then there is an adapted geoR library that performs the cost-based
kriging computations.
Let me know if you need help in applying it to your case.
    ƒacu.-
El mar 06 dic 2011 18:11:52 CET, G. Allegri escribió:
> Does anyone know of implementations of an IDW (or other distance
> weighted interpolators) which can use a cost surface as a
> supplementary weighting factor?
> I'm exploring solutions to do spatially constrained interpolation, and
> modelling barriers through cost surfaces could be a way to do it...
> thanks,
> giovanni
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
