[GRASS-user] Problems to launch QGIS from GRASS
Hamish hamish_b at yahoo.com
Sun Dec 11 20:19:25 EST 2011
José wrote:
> When I check the echo $PATH from within GRASS
> session, this is the message,
> GRASS 6.4.1 (spearfish60):~ > echo $PATH
> /Applications/GRASS-6.4.app/Contents/MacOS/bin:/Applications/GRASS-6.4.app/Contents/MacOS/scripts:/Users/joseca/Library/GRASS/6.4/Modules/bin:/Library/GRASS/6.4/Modules/bin:/Library/Frameworks/GDAL.framework/unix/bin:/Library/Frameworks/PROJ.framework/Programs:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin
> GRASS 6.4.1 (spearfish60):~ > qgis
> bash: qgis: command not found
> I do not know how to solve it but I am very
> grateful to your help.
ah ok, this is a Mac.
first thing to do is to hunt down the qgis executable and get it into one of the $PATH directories.
try like:
ls -l /Applications/QuantumGIS.app/Contents/MacOS/
and look for a qgis file (not directory) with "x" permissions.
once you have that make a symlink into /usr/local/bin
ln -s /Applications/QuantumGIS.app/Contents/MacOS/qgis /usr/local/bin/
you might have to put "sudo" before the symlink to get it to work.
(not sure of exact qgis pathnames, but something
similar to the above)
Hamish
