[GRASS-user] r.in.gdal | libproj.so.0: cannot open shared object file
soumyo1001 soumyo1001 at gmail.com
Mon Dec 19 05:02:12 EST 2011
I'm running GRASS 6.4.1 on my Fedora 15 system. I've installed all the other
required libraries and packages. But each time I run GRASS in gui mode and
start it I get this error : "Unable to get current geographic extent. Force
quiting wxGUI. Please run manually g.region to fix the problem". I'm not
able to run GRASS in gui mode.
Also, when I try to run it from text mode and try to create a raster map
from a sample .jpg file i get this error: "r.in.gdal -o -e
input=/home/user/grassdata/sample.jpg
r.in.gdal: error while loading shared libraries: libproj.so.0: cannot open
shared object file: No such file or directory"
I'm not able to run GRASS for any good. Please help. Also please mention a
good book to start working on GRASS.
Thanks in advance.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-in-gdal-libproj-so-0-cannot-open-shared-object-file-tp7107632p7107632.html
Sent from the Grass - Users mailing list archive at Nabble.com.
