[GRASS-user] Re: mapcalc problem in python script!!
Joshua Arnott josh at snorfalorpagus.net
Thu Feb 3 11:26:47 EST 2011
Johannes,
Looking at your Python code and the error, I expect the issue is with the way you are calling the script, rather than it's content.
From the documentation, g.parser returns a Python dictionary. The options "command" is a variable, rather than a function.
http://grass.osgeo.org/grass64/manuals/html64_user/g.parser.html
The key error occurs when you attempt to access a key, in your case upstream_shreve, when it does not exist.
http://wiki.python.org/moin/KeyError
I suspect the problem is that you're not setting a value for upstream_shreve from the command line, i.e.,
./test3.py upstream_shreve=newmapname upstream_part=upstreammap shreve=anothermap
In your Python script, if you throw in:
print options
You'll be able to quickly check it contains the key-value pairs you expect.
Hope this helps,
Josh.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110203/b43297ad/attachment.html
