[GRASS-user] python pipe Popen to grass.<?>_command
Chris Carleton w_chris_carleton at hotmail.com
Thu Feb 17 22:54:29 EST 2011
Generally, this is the form that I use for python scripts and popen
(these examples are directly from working scripts of mine, but of
course you'll have to adapt them):
subprocess.Popen(
		"v.type input=%(a)s output=%(b)s type=point,centroid --overwrite" %
{'a':VECT,'b':'temp_centroid'},
		shell=True,
		stdout=subprocess.PIPE,).communicate()[0]
or if I don't need to capture data from a GRASS process I use this:
subprocess.call([
		"v.db.update",
		"map=%s" % vect,
		"layer=1","column=%s" % column,
		"value=%s" % value,
		"where=cat=%s" % cat,])
Chris
On 17 February 2011 20:36, Peter Tittmann <ptittmann at gmail.com> wrote:
> Greetings,
> I'm attempting to pipe the results from:
> pts=sub.Popen('las2txt -i %s --parse xyz --keep-classes 2 --delimiter "|"
> --stdout'%path, shell=True, stdout=sub.PIPE)
> to the appropriate grass.?_command('r.in.xyz', etc...)
> i've tried the following:
> mkInRast=grass.feed_command("r.in.xyz", input=pts.communicate()[0],
> output='tester', method='mean')
> which results in:
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
>   File "/usr/lib/grass64/etc/python/grass/script/core.py", line 198, in
> feed_command
>     return start_command(*args, **kwargs)
>   File "/usr/lib/grass64/etc/python/grass/script/core.py", line 148, in
> start_command
>     return Popen(args, **popts)
>   File "/usr/lib/grass64/etc/python/grass/script/core.py", line 53, in
> __init__
>     startupinfo, creationflags)
>   File "/usr/lib/python2.6/subprocess.py", line 623, in __init__
>     errread, errwrite)
>   File "/usr/lib/python2.6/subprocess.py", line 1141, in _execute_child
>     raise child_exception
> OSError: [Errno 7] Argument list too long
> Im pretty sure i'm missing something about how the Popen pipes are accessed
> between these two commands. Any suggestions would be most welcome.
> Best,
> Peter
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
