[GRASS-user] r.mapcalculator / r.mapcalc not producing raster
jaydub justcallmejay at gmail.com
Fri Feb 18 13:29:48 EST 2011
Hi all, I'm trying to combine two raster using the r.mapcalc/r.mapcalculator
but am getting no where. I'm using python.
# I did this previously... so "dem" and "rain" exist as rasters
grass.run_command("r.in.gdal",input="<location>/dem.tif",output="dem")
grass.run_command("r.in.gdal",input="<location>/rain.tif",output="rain")
# Then I try this...
grass.run_command("r.mapcalculator",amap="dem",bmap="rain",formula="A *
B",outfile="test_combo")
The output from that gives me...
r.mapcalc "test_combo" = "( "dem" * "rain" )"
 100%
Done.
When I try to add "test_combo" to the display in GRASS, nothing shows, even
when I try to zoom to the layer in GRASS.
r.info gives me the following:
 | Layer:    test_combo2                    Date: Fri Feb 18 13:19:52 2011
 | Mapset:   PERMANENT                      Login of Creator: jay
 | DataBase: .........                                              |
 | Title:     ( test_combo )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 255
 |   Data Type:    FCELL
 |   Rows:         20
 |   Columns:      20
 |   Total Cells:  400
 |        Projection: Lambert Conformal Conic
 |            N: 707999.97864227    S: 628766.19610209   Res: 3961.68912701
 |            E: 827306.35554785    W: 607862.24148022   Res: 10972.20570338
 |   Range of data:    min = 0.000000  max = 4241302.000000
 |   Data Description:
 |    generated by r.mapcalc
 |   Comments:
 |    dem * rain
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-mapcalculator-r-mapcalc-not-producing-raster-tp6041018p6041018.html
Sent from the Grass - Users mailing list archive at Nabble.com.
