[GRASS-user] Re: r.mapcalculator / r.mapcalc not producing raster
LeeDaniel Lee.Daniel.1986 at gmail.com
Fri Feb 18 14:23:54 EST 2011
With g.region. With the "rast=" argument you can set it to match a raster -
both the spatial extent and the resolution will be set to match.
r.mapcalc uses the regional settings for its calculations, so if the region
is set at a low resolution, or the spatial extent is very small, it could
explain why you're getting such a small raster as a result.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-mapcalculator-r-mapcalc-not-producing-raster-tp6041018p6041173.html
Sent from the Grass - Users mailing list archive at Nabble.com.
