[GRASS-user] Re: Compiling GRASS 7.0 on Mac OSX 10.6.6
William Kyngesburye woklist at kyngchaos.com
Fri Feb 25 20:06:50 EST 2011
TclTk 8.5 Aqua should be compatible with GRASS on OS X, and is preferred over 8.4.
I've been using ActiveTcl 8.5.8 for a while with no problems.  Even latest GRASS 6.5 SVN works.  But after updating to ActiveTcl 8.5.9, I get the compile error.  So it looks like something changed for the worse in 8.5.9.  Maybe that's the Cocoa change.  Bad thing to do in a point release :(
See if you can download 8.5.8.
On Feb 25, 2011, at 11:23 AM, Maris Nartiss wrote:
> Hello,
> as I don't own a Mac and I don't know anybody who does (close enought
> to get a Mac into my dirty hands), I'm not an expert in MacOS X
> internals, still judging from this thread
> http://comments.gmane.org/gmane.comp.lang.tcl.mac/6828 if TCL/Tk NVIZ
> works for You now, do NOT upgrade TCL on Your Mac as some of 8.5
> versions already are incompatible with GRASS Togl copy.
> Backwards incompatible change was introduced: Mon Jun 29 14:35:01 2009 UTC
> http://tktoolkit.cvs.sourceforge.net/viewvc/tktoolkit/tk/macosx/tkMacOSXInt.h?r1=1.32&r2=1.33
> Reason: "Merge of TkAqua Cocoa port"
> As long as You are using pre-Cocoa Tk for GRASS, Your' fine. If
> pre-Cocoa version doesn't work for You, Your' SOL.
> Maris.
> 2011/2/25, William Kyngesburye <woklist at kyngchaos.com>:
>> I don't think Maris meant you can't use TclTk 8.5, but > 8.5, or 8.6+.  8.6
>> is known to have problems.  I haven't built GRASS 7 in a while, but TclTk
>> 8.5 works fine for GRASS 6.x, and is recommended for OS X.
>> I don't know if anything has been changed in GRASS 7.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
