[GRASS-user] problem: boundary lines double
mails-foren at gmx-topmail.de mails-foren at gmx-topmail.de
Sat Feb 26 07:46:21 EST 2011
Hello Markus,
thank you for your advice. Unfortunatly its not possible for me to get clean data. If I import an esri file (16 features) with the command v.in.ogr -o (the o flag is for the locations projection) I get a file with 58 features.
Below I attached the output:
Best regards
v.in.ogr -o dsn=/home/BL2009/Bundeslaender.shp output=test4
Over-riding projection check
Layer: Bundeslaender
Importing map 16 features...
Area size [1.8e-05], area not imported
Area size [8.4e-05], area not imported
Area size [6.3e-05], area not imported
Area size [1.6e-05], area not imported
Area size [2.1e-05], area not imported
Area size [6.7e-06], area not imported
Area size [6.1e-06], area not imported
Area size [2.4e-05], area not imported
Area size [7.2e-05], area not imported
Island size [8.3e-05], island not imported
Island size [5.5e-06], island not imported
Area size [5.5e-06], area not imported
Area size [8.3e-05], area not imported
Area size [5.6e-05], area not imported
Area size [5.5e-05], area not imported
Area size [5.1e-06], area not imported
Island size [5.6e-05], island not imported
Area size [1.1e-05], area not imported
Area size [8.8e-06], area not imported
Area size [1.4e-05], area not imported
Area size [8.5e-06], area not imported
Area size [1.0e-05], area not imported
Area size [3.5e-05], area not imported
Area size [1.3e-05], area not imported
Area size [9.0e-06], area not imported
Area size [3.8e-05], area not imported
Area size [1.5e-05], area not imported
Area size [6.9e-06], area not imported
Area size [3.1e-05], area not imported
Area size [6.4e-05], area not imported
Area size [6.5e-06], area not imported
Area size [2.2e-05], area not imported
Area size [7.0e-06], area not imported
Area size [9.3e-06], area not imported
Area size [7.1e-06], area not imported
Area size [1.2e-05], area not imported
Area size [6.0e-05], area not imported
Area size [6.2e-06], area not imported
Area size [1.9e-05], area not imported
Area size [6.4e-06], area not imported
Area size [5.9e-06], area not imported
Area size [2.5e-05], area not imported
Area size [7.8e-06], area not imported
Area size [8.2e-06], area not imported
Area size [3.0e-06], area not imported
Area size [8.7e-05], area not imported
Area size [5.7e-06], area not imported
Area size [6.1e-05], area not imported
Island size [1.6e-05], island not imported
Island size [1.1e-05], island not imported
Island size [8.8e-06], island not imported
Island size [2.2e-05], island not imported
Building topology for vector map ...
Registering primitives...
61 primitives registered
197855 vertices registered
Building areas...
59 areas built
59 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 60
Number of primitives: 61
Number of points: 0
Number of lines: 0
Number of boundaries: 61
Number of centroids: 0
Number of areas: 59
Number of isles: 59
Number of incorrect boundaries: 2
Number of areas without centroid: 59
Cleaning polygons, result is not guaranteed!
Number of nodes: 60
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Break polygons:
Remove duplicates:
Break boundaries:
Remove duplicates:
Clean boundaries at nodes:
Change dangles to lines:
Remove bridges:
Building areas...
60 areas built
45 isles built
Number of nodes: 88
Number of primitives: 163
Number of points: 0
Number of lines: 0
Number of boundaries: 163
Number of areas: 60
Number of isles: 45
Number of areas without centroid: 60
161 primitives registered
155800 vertices registered
Building areas...
60 areas built
45 isles built
Number of nodes: 146
Number of primitives: 161
Number of points: 0
Number of lines: 0
Number of boundaries: 103
Number of centroids: 58
Number of areas: 60
Number of isles: 45
Number of areas without centroid: 2
119 input polygons
Total area: 4.596540e+01 (60 areas)
Overlapping area: 0.000000e+00 (0 areas)
Area without category: 4.309415e-03 (2 areas)
Successfully finished
-------- Original-Nachricht --------
> Datum: Wed, 2 Feb 2011 15:42:15 +0100
> Von: Markus Metz <markus.metz.giswork at googlemail.com>
> An: mails-foren at gmx-topmail.de
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] problem: boundary lines double
> On Tue, Feb 1, 2011 at 4:43 PM,  <mails-foren at gmx-topmail.de> wrote:
> > Hello Maris,
> > thanks a lot for replying.
> > Yes, I imported an esri shapefile. I'd tried to clean data with v.clean
> and with many different grass clean modules, without any success.
> > Any other idea how to solve this issue? Maybe there is a method to
> import esri shapefiles without saving double the boundary?
> The imported shapefile should be clean if v.in.ogr was not used with
> the -c flag, i.e. v.in.ogr did topological cleaning. Duplicate
> boundaries should not exist when using v.in.ogr with default settings.
> Markus M
> >> Datum: Thu, 27 Jan 2011 21:35:17 +0200
> >> Von: Maris Nartiss <maris.gis at gmail.com>
> >> Hello,
> >> looks like Your data are coming from non-topological vector storage
> >> (Shapefile?). Cleanness of data stored in non-topological formats
> >> (i.e. Shapefile) depend on data creation software abilities to produce
> >> cliean-look data and not are enforced by data storage, as it is in
> >> GRASS.
> >> Without seeing more information, my guess would be - You imported
> >> shapefile with areas into GRASS, still they had slivers and thus
> >> feature count has increased. Only way out is to clean data with
> >> v.clean and friends or by hand.
> >> Maris.
> >> http://grass.osgeo.org/grass64/manuals/html64_user/v.clean.html
> >> 2011/1/27, mails-foren at gmx-topmail.de <mails-foren at gmx-topmail.de>:
> >> > Hello,
> >> > if I import a shape (414 features) with v.in.ogr.qgis I get output
> with
> >> 594
> >> > features. I had read the problem is, that a boundary line between two
> >> > polygons get saved double. How can I manage to save as one boundary
> line
> >> > between two polygons?
> >> > Thanks a lot in advance!
> >> > Steffen
> >> > GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
> >> > gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
> > NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> > Jetzt informieren: http://www.gmx.net/de/go/freephone
