[GRASS-user] using r.resamp.stats- When I reach a tie
António Rocha antonio.rocha at deimos.com.pt
Mon Feb 28 03:50:56 EST 2011
Hi Glynn.
Thanks for your answer. Is there any other alternative, to resample
data, that uses another approach to solve tie events?
THanks
Antonio
Glynn Clements wrote:
> António Rocha wrote:
>> I'm planning on using r.resamp.stats in order to  resample a grid to a
>> coarser resolution. Since I'm using this function with classes I will
>> use mode method (more frequentclass to fall into a destination cell is
>> the chosen). My question is: when I have a tie between two classes, how
>> does GRASS decides which class shall be chosen?
> In the event of a tie, the lowest-numbered category is chosen.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5912 (20110227) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
