[GRASS-user] calculating average value over a base map
Christian Schwartze christian.schwartze at uni-jena.de
Mon Feb 28 12:08:47 EST 2011
If you want to deal with raster value types other than CELL, you can use the –c flag in r.statistics in order to process the labels. Therfore, you have to copy your cat values to the category labels first...
Regards,
Christian.
Sent: Monday, February 28, 2011 5:16 PM
To: Christian Schwartze
Cc: GRASS user list
Subject: Re: [GRASS-user] calculating average value over a base map
Greetings Christian
Unfortunely it only works with CELL values. For instance, r.median uses more than just CELL.
Is there any other alternative? Beucase for mode and median there is specific functions.
Thamls
Best regards,
Monica
On Mon, Feb 28, 2011 at 3:55 PM, Christian Schwartze <christian.schwartze at uni-jena.de> wrote:
  Monica,
  try to use r.statistics with the average function/method. Pass you maps through the cover= and base= parameters...
  Christian.
  Sent: Monday, February 28, 2011 4:27 PM
  To: GRASS user list
  Subject: [GRASS-user] calculating average value over a base map
  Greetings
  I have a map with values and a base map created with r.clump. How can I calculate the average of values that falls inside each cluster defined by r.clump?
  Thanks
  Best regards,
  Monica
  grass-user mailing list
  grass-user at lists.osgeo.org
  http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110228/c6e32dae/attachment.html
