[GRASS-user] GRASS wxpython error in ubuntu 11.04
Pierre Roudier pierre.roudier at gmail.com
Wed Jul 6 01:15:42 EDT 2011
Andry,
Yes, I think I've already went through that problem. For some reasons
the Ubuntu folks have an unstable/old version of GRASS in the default
repository. This is bad.
Two solutions:
- First one, compile it from source, if you're confident with that
sort of things.
- Otherwise, there is a special Ubuntu repository for spatial
software, UbuntuGIS: https://launchpad.net/~ubuntugis/+archive/ppa/ .
What you need to do is to add that repository to your system. Then
install GRASS from that repository.
Maybe an Ubuntu user could comment - I'm on OpenSuse so I may not been
up-to-date,
HTH,
Pierre
2011/7/6 andry rustanto <rustanto.id at gmail.com>:
> Hi Pierre,
> Thanks for your reply, yes i installed it from synaptic from local
> repository in Indonesia. How can I upgrade my GRASS into version 6.4.1 ?
> Many Thanks,
> Andry
> On 6 July 2011 11:34, Pierre Roudier <pierre.roudier at gmail.com> wrote:
>> Hi Andry,
>> Your seem to be running an unstable and rather old version of GRASS
>> (GRASS 6.4.0+42329). First thing you should do is to update to the
>> newest stable version (6.4.1).
>> How did you install it? If from Synaptic, from which repository?
>> Pierre
>> > Dear All,
>> > Please help me to start GRASS -wxpython i ubuntu 11.04, it gives error
>> > as
>> > follow :
>> > GRASS 6.4.0+42329 (New):~ >
>> > (python:3254): GLib-CRITICAL **: g_hash_table_insert_internal: assertion
>> > `hash_table != NULL' failed
>> > Traceback (most recent call last):
>> >   File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 1818, in <module>
>> >     sys.exit(main())
>> >   File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 1811, in main
>> >     app = GMApp(workspaceFile)
>> >   File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 1736, in __init__
>> >     wx.App.__init__(self, False)
>> >   File
>> > "/usr/lib64/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
>> > line 7978, in __init__
>> >     self._BootstrapApp()
>> >   File
>> > line 7552, in _BootstrapApp
>> >     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>> >   File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 1754, in OnInit
>> >     workspace = self.workspaceFile)
>> >   File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 185, in __init__
>> >     self.NewDisplay(show=False)
>> >   File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 1235, in
>> > NewDisplay
>> >     auimgr=self._auimgr, showMapDisplay=show)
>> >   File "/usr/lib/grass64/etc/wxpython/gui_modules/wxgui_utils.py", line
>> > 73,
>> > in __init__
>> >     super(LayerTree, self).__init__(parent, id, pos, size, style=style,
>> > ctstyle=ctstyle)
>> >   File
>> > "/usr/lib64/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/mixins/treemixin.py",
>> > line 488, in __init__
>> >     super(DragAndDrop, self).__init__(*args, **kwargs)
>> > TypeError: __init__() got an unexpected keyword argument 'ctstyle'
>> > Many Thanks...
>> > Regards,
>> > Andry
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>> Scientist
>> Landcare Research, New Zealand
Scientist
