[GRASS-user] Ubuntu and Grass - which versions/combinations?
Thomas Adams Thomas.Adams at noaa.gov
Thu Jul 14 07:52:18 EDT 2011
  Sharon,
I pretty much agree with Paulo; I would add that the following link
(http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu) helped me a
lot. I'm using Ubuntu 11.04 and compiled GRASS 6.4.1, which I highly
recommend using.
Regards,
Tom
On 7/14/11 4:02 AM, Paulo van Breugel wrote:
> Hi Sharon,
> GRASS version 6.4 rc6 is in the repository, so installing GRASS should
> be very easy. Just open the Ubuntu software center and search for
> GRASS (you probably want to install the optional packages listed too.
> (BTW, I would go for the latest Ubuntu or alternatively for the latest
> long-term supported version, check the Ubuntu page for more details).
> I have compiled GRASS myself (6.4.1 and 7, which you can install
> both), mainly because at the time I started to use it on Ubuntu, the
> GRASS version in the repositories was rather old. Moreover, it allows
> greater control over how GRASS is setup. And although initially a
> pain, when set up and all dependencies are installed, subsequent
> updates are easy.
> It is still not the most recent release, but if you want to use the
> latest stable release (6.4.1), you don't have to compile it yourself.
> You can just add a PPA, which makes installing the latest stable
> version fairly simple too. I don't know how familiar you are with
> Ubuntu and the use of software sources, but have a look at
> https://launchpad.net/~grass/+archive/grass-stable
> <https://launchpad.net/%7Egrass/+archive/grass-stable>.
> Cheers,
> Paulo
> On Thu, Jul 14, 2011 at 9:39 AM, Sharon M <morrisxs09 at gmail.com
> <mailto:morrisxs09 at gmail.com>> wrote:
>     I currently use winGrass on Win XP - mainly importing shape files,
>     data loads to dbf, various vector modules for analysis and
>     ps.map.  I experience a few issues with winGrass, so would like to
>     try Grass on Ubuntu - see if I can eliminate some Grass issues.
>     I'd be using Ubuntu installed via wubi (because it's a win XP
>     laptop).
>     Does anyone using Ubuntu/Grass have suggestions as to which
>     version(s) of Ubuntu and versions of Grass are the most stable /
>     reliable combinations? and importantly easiest to install and set up.
>     Any links to help for setting up Grass on Ubuntu (or Linux
>     generally) also appreciated.
>     Thanks in advance.
>     Sharon
>     _______________________________________________
>     grass-user mailing list
>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110714/8372f2b0/attachment-0001.html
