[GRASS-user] Re: raster stats within vector
Paulo van Breugel p.vanbreugel at gmail.com
Sun Jul 17 04:27:22 EDT 2011
v.rast.stats (menu: Vector-Update area attribute from raster) will
calculate n, min, max, range, mean, stddev, variance, coeff_var, sum and
optionally the 1st quartile, median, 3rd quartile, and given percentile.
Columns will be created on the fly, you only have to give the 'base
name' of the columns. I.e., no need to create a column yourself.
On 07/16/2011 10:14 PM, Milton Cezar Ribeiro wrote:
> BTW,
> my vector maps have polygons.
> milton
> 2011/7/16 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com
> <mailto:miltinho.astronauta at gmail.com>>
>     Dear all,
>     I have a raster map with continuous values, and need to extract
>     some stats (like mean, std etc) assigning these "zonal" values as
>     a vector column.
>     I just added the empty columns on the my vector map using :
>           v.db.addcol map=frag_ts columns="FLOW_STD DOUBLE PRECISION"
>     How can I do this on grass?
>     cheers
>     milton
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110717/ef9c83cf/attachment.html
