[GRASS-user] Defining a State Plane Coordinate Location
Markus Neteler neteler at osgeo.org
Sun Jul 24 11:38:10 EDT 2011
On Sun, Jul 24, 2011 at 2:57 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Sun, 24 Jul 2011, Markus Neteler wrote:
>> Better use
>> - the wxGUI location manager from the startup screen
> Markus,
>  This is what I've tried. When I select STP as the projection I'm told that
> I need to manually enter the definition.
>> - or create the location from a GIS file (shape, geotiff, ..) with correct
>>  metadata
>  This, of course, would be too easy ... if such a map was available. None
> of the data I've collected is in SPCS, unfortunately.
>> - or create from the EPSG code
>>  (is it this one?http://spatialreference.org/ref/epsg/3429/ )
>  I'm not sure.
See also
http://spatialreference.org/ref/epsg/32107/
(or check on http://epsg-registry.org/ )
Markus
